rear window replacement
Postby adamaca » Thu, 04 Mar 2010 10:08 +0000
How much does it cost to get a plastic rear window replaced these days?
adamaca
Re: rear window replacement
Postby charged_rs » Thu, 04 Mar 2010 10:21 +0000
i stopped fitting rear screens ages ago as its cheaper and easier to fit a new hood.
if your back window has gone...its a sure bet on a fixed odd the rest of your hood isnt far behind.
£130 ish for vinyl on ebay , but they are the bottom of the barrel for el cheapos
Postby sidewaysreilly » Fri, 05 Mar 2010 3:04 +0000
so, how much to supply and fit a top quality mohair in tan??????
Postby charged_rs » Fri, 05 Mar 2010 11:44 +0000
£330 mk1
£360 mk2 - with heated glass rear window
or if you supply the hood -£80 fitting
price includes brand new hood tensioner cables
For an extra £20 i can scotch guard them aswell - helps stop the dirt sticking to them and seals them
i supply the hood already on a frame , you drive in , i swap the frames over and 90 mins later you drive away with new hood and frame. Job done.
Postby sidewaysreilly » Fri, 05 Mar 2010 12:29 +0000
Good stuff. Looking to get a new one in the very near future.
Postby sundance » Fri, 05 Mar 2010 1:59 +0000
I take it the mohair roof for mk1 would still have a plastic rear window and not glass?
sundance
Postby Steve » Fri, 05 Mar 2010 3:42 +0000
charged_rs wrote:or if you supply the hood -£80 fitting
Nice!
Postby charged_rs » Fri, 05 Mar 2010 4:25 +0000
sundance wrote:I take it the mohair roof for mk1 would still have a plastic rear window and not glass?
unless you give me a glass window it will be vybak - clear plastic.
i have a few mk2 rear glass screens i use on an exchange basis.
If you wanted a HRW glass on a mk1 frame - add another 75 ontop - thats only if you dont have one currently
Postby adamaca » Tue, 09 Mar 2010 4:11 +0000
Where can one purchase a plastic rear window?
adamaca
Postby charged_rs » Tue, 09 Mar 2010 4:22 +0000
ive tried mate and i cant get them for sensible money.
try autolinkuk
Postby R-Ltd » Tue, 09 Mar 2010 11:51 +0000
I have a back panel with a nearly new plastic window professionally sewn in to the original mazda hood with the mazda zip. The panel colour is dark blue and not black (off a 1995 R-Limited). I swapped over to a glass window mark 2 roof. Straightforward swap if you still have the Mazda zip (has Mazda emblem on slider). Forty euro plus post or collect in Cork. John R-Ltd
1995 Eunos R-Limited (SOLD)
2007 NC in Copper Red with RHT
R-Ltd
Postby dabofoppo » Thu, 29 Jul 2010 2:20 +0000
charged_rs wrote:£360 mk2 - with heated glass rear window
is this the price for a mohair hood?
if so, what is the price for a vinyl hood?
dabofoppo
Postby charged_rs » Thu, 29 Jul 2010 3:06 +0000
prices have gone up unfortunately :( , like everywhere is doing it
mk1 mohair with vinyl is £360 supplied and fitted,
mk2 mohair with glass is £380 supplied and fitted
mk1 with glass...i dont supplu as the zips always break under the stress ( weight of the glass)
if you have a mk1 and want a glass window , you are better getting a mk2 hood and frame fitted.
some examples of my work / hoods are below
the white marks around the hood on this one are chalk and i forgot to wash them off :cyclops:
Postby fabfiveferg » Thu, 29 Jul 2010 4:01 +0000
My experience recently has been that prices are in fact coming down. Like everywhere
Postby dabofoppo » Thu, 29 Jul 2010 4:03 +0000
charged_rs wrote:mk1 mohair with vinyl is £360 supplied and fitted,
i have a mk2, do you have vinyl hoods for these? (with glass)
if so, what is the price?
dabofoppo
Return to Leaks
