leaking back window
leaking back window
Postby jayryan » Wed, 30 Jun 2010 7:44 +0000
Hi my back window on my soft top is leaking.There are no tear or reps in the fabric.Could it just need water proofing?
jayryan
Re: leaking back window
Postby leamyj » Wed, 30 Jun 2010 11:28 +0000
Have you been able to determine exactly where the water's getting in??, is it at a point where the plastic ( if your window's plastic) meets the rest of the roof?? is it along a zip??
A little trick to determine where water is getting in is to sprinkle talcum powder in the suspect area and observe what happens as you put water to the exterior.
Is the parcel shelf getting wet?..check the rain rails..Drain holes been cleaned lately??
Basically, be certain of where the water is getting in, that will determine the next course of action.
As there's no tears/rips, I suspect your rain-rail is either cracked or blocked,or drains are clogged up with gunk.. this would result in a wet rear parcel-shelf
Postby sidewaysreilly » Wed, 30 Jun 2010 11:35 +0000
talcum powder to find the wet bits eh????? must remember that one :wink: :wink:
Postby CashelMX5 » Thu, 01 Jul 2010 5:21 +0000
Still at the nappies John ? :lol: :lol: :lol: :mrgreen: :alien:
Postby jayryan » Thu, 01 Jul 2010 11:21 +0000
Hi ive cleaned out the drain plugs,and reproofed the roof and window so im hoping that works. :)
jayryan
Postby leamyj » Fri, 02 Jul 2010 12:28 +0000
CashelMX5 wrote:Still at the nappies John ? :lol: :lol: :lol: :mrgreen: :alien:
WELL past that stage now Tom :lol: About the only use you can make of the cheap talc that some people pass as presents over the years :mrgreen: :mrgreen:
Return to Leaks
