mk2 glass window seal leaking
Postby james » Tue, 14 Aug 2012 11:06 +0000
how can a fix this is every time its been raining i get a few drops coming in from under the seal
james
Re: mk2 glass window seal leaking
Postby Paschal » Wed, 15 Aug 2012 11:35 +0000
Me too. Its where the frame folds in the middle. I see there is a bit of rust on mine. No idea how to solve it though but then again have not looked at it too hard
Postby MX5Spares » Wed, 15 Aug 2012 5:21 +0000
Common problem ,may need new seals but I have adjusted the restrictors ,that let the closed height of the window in the door itself close high/low etc.There are 2 x 10mm nuts inside the door trim panel itself at the top of the metalwork where it meets the glass .You can loosen these and pull the glass up slighty,but not too much,and tighten the nuts while glass is held up.Might help but don't bang the door too hard till you are happy with the position of the glass!!!!
Postby james » Wed, 15 Aug 2012 9:14 +0000
:? so lifting up the front window screen frame basicly
james
Postby leamyj » Thu, 16 Aug 2012 12:39 +0000
james wrote::? so lifting up the front window screen frame basicly
Kinda, more like adjusting the restrictor/limiter. When you see them you'll know what I mean 8)
Postby charged_rs » Thu, 16 Aug 2012 1:50 +0000
leaky window seals are usually caused by 2 things
your seals just need revitalised - try smearing a light coat of vaseline over them for 24 hours then wipe it off- this causes them to swell and make a better seal.
the other problem you might be having is that your softtop has shrunk , exposing the metal fitting that the seal fit into , and what happens is , water soaks in from behind the seal , fills , the seal then drips down on you. - the cure here is a new softtop or doing some sort of bodge with copious ammounts of silicone
Postby james » Thu, 23 Aug 2012 5:15 +0000
the window is not being pulled tight and it has silicone on the inside
james
Postby charged_rs » Fri, 24 Aug 2012 5:31 +0000
james wrote:the window is not being pulled tight and it has silicone on the inside
post a picture up of what your window looks like....cant picture what you are describing.
Postby james » Tue, 28 Aug 2012 11:41 +0000
will do =]
james
Return to Leaks
