Rear window
Rear window
Postby Pops » Tue, 26 Feb 2019 6:21 +0000
The plastic rear window has fallen in on one side, in an attempt to fix it I’m using epoxy glue, no idea if it’ll work but worth a try
The cheap lidl/aldi vice grips getting a bit of use
Re: Rear window
Postby mrges » Wed, 27 Feb 2019 12:16 +0000
Hopefully that'll be a cheap fix.
Re: Rear window
Postby Steve » Wed, 27 Feb 2019 10:58 +0000
would be interested to hear if this does the job.
If it doesn't, maybe one of the local sail makers/marine shops could suggest something?
Re: Rear window
Postby Pops » Wed, 27 Feb 2019 2:34 +0000
It was left till now so that the glue can set fully, of course there wasn’t enough glue in the one shot syringe to do the full length but I’ll be happy for now if this much holds.
The zipper closed much easier so can only be better.
Still thinking of changing it for a mohair top though
Re: Rear window
Postby mrges » Wed, 27 Feb 2019 6:06 +0000
Looking good so far - but is say 'go mohair'.... looks better, lasts longer.
Return to Leaks
