Clutch pedal free play
Re: Clutch pedal free play
Postby Steve » Sun, 06 Jan 2013 11:28 +0000
done ;-)
Postby Steve » Tue, 15 Jan 2013 1:04 +0000
Put a new master cylinder in on Sat, bled it and the slave cylinder, job done.
Postby Merlot man » Tue, 22 Jan 2013 10:33 +0000
How much work is involved in replacing master cylinder ,rods book says it a bitch ,think it's disconecting rod from peddle to cyd on bulk head is the hard bit ,any views?
Considering doing master cylinder, slave and cluch line at some stage myself.
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Postby Steve » Tue, 22 Jan 2013 11:10 +0000
Its very easy to replace, 15 mins tops, less if you have someone to help you.
Remove slave and let fluid drain from the clutch line, remove hard line from the side of the master, you'll need 10mm flare wrench like this :
Then one bolt on engine side of the firewall and one up behind the clutch pedal on the other side. I left the rod in place.
Throw on the new slave + line, fill the new master with fluid and move the plunger in and out until fluid comes out of the hole, cover the hole with your finger and hook it up to the hard line (much easier to do before you bolt it back to the firewall). The fiddly bit is getting the rod back into the plunger hole, if on your own it might take a couple of trips back and forth under the dash till you line it up. Bolt up and bleed.
If you go for a braided clutch line, its much easier to bleed as you'll be removing the curly line down near the slave which tends to hide air bubbles.
Postby Merlot man » Wed, 23 Jan 2013 11:50 +0000
Thanks for that Steve.Do you know if the ss lines are still available from the group buy you had last ,year if so I would be interested ,will talk about next time we meet
Thanks again
Brian
93 na s ltd
Merlot man
Postby Steve » Thu, 24 Jan 2013 11:54 +0000
Can probably hook you up with contact details for the guy I ordered them from. They were made to order so not sure if he has any left over, worth asking though.
Postby Merlot man » Mon, 28 Jan 2013 4:21 +0000
Thanks Steve hope to meet up next Galway c&c
Brian
93 na s ltd
Merlot man
