And a comparison shot
HubahubaFitted me cam cover - looking good.
And a comparison shot ![]() ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
Wait till i get me spare intake manifold to work on. Will get it done same as the cam cover.
And i have a nice surprise coming from usa. ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
i see you broke your dipstick like mine too!
ohhhh, do tell whats in the post from the states.......don't leave us in SUSPENDERZ! ![]()
jrcai.
Yeah must get a new dip stick. off to ebay i go. ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
Ash, did you get new bolts for the cam cover?
and is so, where did you get em? also, did you replace the gasket whilst you had it off? Rgds, Ollie. ![]()
No i used the old bolts, You can get them from http://www.boundville.co.uk/engine-parts-33-c.asp for a quid each or the front ones which are different from mx5parts, (steve did you ever get some for your car?)
Yeah i did replace the gasket, I've had the old one off twice and reused it so thought it best to replace it this time. Just a quick note if you do take off your cam cover for any reason don't forget to have some gasket sealant handy. You need to apply a couple of dabs when refitting. ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
Probably best to the first few times, it doesn't take much to tighten them down and/or snap them in half.
Prob should be didn't, kind of got a feel for it at this stage (done it 3 times
Sorted i've made my self one. Looks pretty good. ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
Undoubtably its a polished lacquered one? ![]()
LOL polished indeed. I'll grab a pic sometime, simple solution but looks better than a bit of broken yellow plastic.
