L.S.D
L.S.D
Postby adamaca » Sat, 14 Feb 2009 8:00 +0000
A friend is looking to put a lsd into his mk1 1.6. what would be needed to put an aftermarket diff from a mk2 1.6 or 1.8 on his car?
Any advice welcome.
Regards
Adam
adamaca
Postby Steve » Sat, 14 Feb 2009 8:22 +0000
should be a straight swop if its a 1.6 car for a 1.6 diff? The gears unbolt and you pop in the new one AFAIR.
For a 1.8.. you'll need 1.8 half shafts, prop shaft and diff "pumpkin".
See here (the pics are a little out of order.. will fix one of these days)
http://www.mx5ireland.com/members/srigley/writeup/Installing%20a%201800cc%20diff2.htm
