Soft top heated windscreen
Guys
Finally took the hard top off yesterday but by windscreen heater (rear) doesn't seem to be working with the soft top.
All was OK with the hard top, so I guess that means connections through the car are good. I've unplugged and replugged connectors in/swapped polarity (although not sure this matters) and chased cables to see if there was a kink/split etc Nothing obvious to see apart from what appears to be a slight rust colour around the connections to the window. I think that's always been there, can't be sure. Could be oxidation I guess, causing a bad contact?
The light doesn't go on from the dash, so I'm assuming it's an electrical fault.
Any thoughts before I get my soldering iron out?
Thanking you as always
Shena
Shena
