power steering
Mon, 27 Apr 2009 12:34 +0000
by briantec
lads i have a 98 mk1. every now and again my power steering just goes. it doesent seem to make a difference if it hot or cold. fluid is good and most times its when im sideways
not good
any ideas thanks
Re: power steering
Mon, 27 Apr 2009 9:39 +0000
Sounds like your pump is pumping air rather than fluid for those moments.. fluid churned up by the pump will airate (spl?).
I'd suggest changing your fluid.. try and get Redline PS fluid its formulated to avoid the airation (seriously.. is this how its spelt?).
When draining, undo the lowest part of the return line and turn the rack fully from one side to the other to pump out the fluid in the rack.
Re: power steering
Mon, 27 Apr 2009 9:56 +0000
by briantec
sound. was thinking something like that. i will try it thanks
