Gearbox rear oil seal
Postby K10 » Mon, 04 May 2009 6:15 +0000
Has anyone replaced this? I need to do it as mine seems to be weeping.
Are there any tricks to it, I presume it just takes a bit of brute force to get the gearbox tail-nut undone and that's about it.
£14 for a seal from MX5parts is a bit rich too.
http://www.corkmongolia.com
K10
Re: Gearbox rear oil seal
Postby franksm » Mon, 04 May 2009 10:42 +0000
Prop-shaft has to come off, that's the hardest part. Then you just pick out the old seal carefully and press in the new seal - oil the seal before you put it back in, and press it in with a socket of the right size.
Oh yeah, drop the oil out of the gearbox before starting the above :-)
I put a bit of Loctite on the propshaft bolts too when I do them up - best to be safe
