1.8 Ignition Timing anyone????
Postby sidewaysreilly » Mon, 05 Oct 2009 6:30 +0000
Anyone here adjusted their ign timing???
Book i got was for a 1.6 and says to increase advance to 14 degs after fitting induction kit. Not sure about 1.8 tho.
Re: 1.8 Ignition Timing anyone????
Postby Steve » Mon, 05 Oct 2009 9:12 +0000
yeah, the same 'cept the CAS is on the other side of the cam cover.
Postby sidewaysreilly » Mon, 05 Oct 2009 9:44 +0000
yeah Steve but is it ok to go to 14 btdc?????
Postby Steve » Mon, 05 Oct 2009 11:49 +0000
yeah, its the same.
More on the topic here
Postby sidewaysreilly » Tue, 06 Oct 2009 12:18 +0000
Thanks lad, thats a great read and explains it very well.
Postby Richie L » Wed, 07 Oct 2009 10:44 +0000
I have a K&N typhoon fitted to my 1.8 mk 2.5
Should I advance the timing gents?And yes I do want it to go faster at the detriment to the environment.
Richie L
Postby Steve » Wed, 07 Oct 2009 5:24 +0000
I don't think its possible on that engine without some modification as the ECU will readjust to compensate AFAIR.
Postby Richie L » Wed, 07 Oct 2009 9:49 +0000
Thanks Steve
Richie L
Postby sidewaysreilly » Wed, 07 Oct 2009 9:51 +0000
maybe its just the noise but i cant detect any improvement with the K&N at all. Ill wait till i adjust the timing but seems a waste of money.
Postby sidewaysreilly » Sun, 11 Oct 2009 11:26 +0000
update; got a decent Timing Light from E Bay and set timing to 14btdc....very difficult to see marks with all the P/S and A/C gubbins. Removed the last bend in the Inlet Trunking up to the bellows and put K7N on here. Filter is now behind Headlight unit. I will make up proper brackets as its nestling in front of shock mount. Car is now much more responsive at slight throttle and is as quite as standard almost . No room for the cold air trunking so brought it from grille up thro bonnet catch hole and directed it at filter.Happy days, Aimee is very pleased also. Most important. Mazdaspeed bar has stiffened up the rear big time.Must get some pics up when i make a shield up.
