Wheel Bearing question
Postby leamyj » Sun, 14 Feb 2010 3:52 +0000
Guys, I have a drone coming from the rear LHS wheel for some time now( about 2 years to be more honest). I'm pretty sure that it's a bearing problem. Did a quick check and couldn't feel any play in the wheel, but then I'm no expert!!
Is there adjustment on the bearing or does it need to be replaced?? I have a friend who is a mechanic and he asked me that question, to which I don't have the answer, so over to those who know!!
It's a mk1 1.6 pink special :mrgreen: :mrgreen: :mrgreen:
(If you can't beat them, join them)
Re: Wheel Bearing question
Postby sidewaysreilly » Sun, 14 Feb 2010 4:05 +0000
John, there is a good section in your Rods Miata book 9;18 . Says .05mm limit but if its noisy, change it. Easy job to do and bearings are not too dear.
Postby leamyj » Sun, 14 Feb 2010 4:15 +0000
Thanks Seán, had a quick look there now. I'll give yer man a look at it and let him decide.
Postby Steve » Sun, 14 Feb 2010 4:24 +0000
Hey John,
Couple of things to try :
have a passenger listen and see where they think its coming from.. might just be your diff...
swop your front wheel with your rear wheel and see if the noise moves with it,
you could try tightening your hubnut before replacing the bearing, might just need a slight turn (it was for me).
Postby leamyj » Sun, 14 Feb 2010 6:14 +0000
srigley wrote: might just be your diff...
Just??.. Thanks Steve, now I'm gonna be paranoid about my diff :shock: :shock: :mrgreen:
