leak in cooling system
Postby adamaca » Tue, 23 Feb 2010 11:53 +0000
I was driving home last night noticed the temp seemed to be running quite high somewhere around the 2/3 - 3/4 mark, when i got onto the motorway in top gear it went back to normal. I had a look when I got home and there seemed to be a leak somewhere under the plenum chamber dripping down onto oil filter and i think the altenator.
Anyone any ideas?
adamaca
Re: leak in cooling system
Postby Steve » Wed, 24 Feb 2010 12:04 +0000
*edit*
Teena is right, check this :
http://www.miata.net/garage/water_pump.html
Postby TeenaG » Wed, 24 Feb 2010 12:14 +0000
...you got the benefit of some air-cooling when you hit the motorway... Water pump?
TeenaG
Postby adamaca » Wed, 24 Feb 2010 12:43 +0000
Where is the water pump mounted?
adamaca
Postby franksm » Wed, 24 Feb 2010 4:34 +0000
Could also be the electric fan - does it spin fast when the engine is hot ?
If it doesn't spin, it or its relay is bollixed.
If it spins slowly, the motor has worn bushes - the whole thing will need replaced.
I put a Kenlowe fan on mine when it started to fail - same symptoms as you describe.
Postby adamaca » Wed, 24 Feb 2010 5:24 +0000
Fan works fine, ive checked that. The heater doesnt seem to get really hot either.
The car car also recently had the thermostat replaced I believe, but there is definitly a leak somewhere and its dripping onto the altenator and oil filter. I wonder is it just a case of sorting the leak?
adamaca
Postby franksm » Wed, 24 Feb 2010 5:41 +0000
Fix leak and bleed, should get you to a good place anyway.
Bleeding = running it with the rad-cap open and allowing the air out, and massaging all of the pipes to and from the rad.
