Diff and Gearbox oil - which one?
Postby johnc55 » Thu, 25 Feb 2010 1:38 +0000
Went to buy oil for a diff and g'box change.
Got totally confused.
I think I am looking for 2 litres 75W90 for G'box and 1 litre SAE90 for the diff.
In Halfords, lots of choice for different oils but not at the same rating numbers and to make matters worse, their own oil recommendation chart lists the same oil for both but at a rating of 70W80 or something like that but not the same as what I think I need.
Can anyone recommend a brand/no. for me?
Or will the same do for both?
Don't want to go into the local motor factors and be fobbed off with a 'sure this is just as good and will do for both' kind of answer.
Any suggestions?
thanks in advance
JohnC
johnc55
Re: Diff and Gearbox oil - which one?
Postby ger » Sat, 27 Feb 2010 3:47 +0000
redline or silkolene are probably the best
I've been using this one in both gearbox and diff, would recommend.
http://www.opieoils.co.uk/p-832-silkolene-pro-srg-75-full-ester-synthetic-ester-racing-gear-oil.aspx?message=true
Its available from murray motorsports for 20 a litre (2 for the box 1 for the diff)
Postby johnc55 » Sat, 27 Feb 2010 5:21 +0000
Thanks Ger.
Got some redline @ €15 a litre in couture auto. Will try that.
johnC
johnc55
