Fitting a Torsen type 2 Limited Slip Differential
Bit of a hassle finding the one i wanted without being robbed. Trawled all the breaker sites and finally got the one i wanted from a wrecked 2003 model with shaft included for ............75 euro!!!!!!! Went to Monaghan in the 5 to collect it but was'nt told it was still in the complete rear sub-frame. The top ally support was broken hence the low price but the ppf frame was a bitch to get free.
Anyways.......ill keep adding pics as the job develops.
The later type 2 torsen addressed all the problems of the earlier type 1. i.e......one wheel loses all grip......yer fecked. The type 2 has washers for preload to stop this happening so its a true lsd. Same as Honda s2000 i think?
The diff came from a 2003 6 speed so the final drive ratio is 3.63-1 which is way wrong for the green meany. Ill be swapping over my crown wheel and pinion when i get some free time.
