alternator belt and engine number(code)
Postby decoy » Wed, 16 Mar 2011 5:05 +0000
ive started two threads on the mx5oc forum, but i dont feel like ive received the necessary info/data.
alternator: http://www.mx5oc.co.uk/forum/forums/t/27036.aspx
engine: http://www.mx5oc.co.uk/forum/forums/t/27289.aspx
help please
thanks
decoy
Re: alternator belt and engine number(code)
Postby Steve » Wed, 16 Mar 2011 10:29 +0000
Looks like you have the alternator belt sorted now? Mine is also a large toothed belt (the PS belt is v.ribbed).
Can't answer the engine code question, but you'll find the code on the driver's side of the block near the rear where it meets the cylinder head.
Postby decoy » Wed, 16 Mar 2011 6:31 +0000
thanks found it, it ended up being a B6****** yaaay 115/120 horsies instead of only 88
decoy
