limited
limited
Postby decoy » Tue, 22 Mar 2011 7:28 +0000
Not so much a problem. but recently found out that the car is limited to 115Mph where as the car can do 135.. kinda gutted.
decoy
Re: limited
Postby leamyj » Tue, 22 Mar 2011 7:38 +0000
Surely only an issue if you're taking it on a track?? :twisted: :twisted:
I think that it's possible to alter that limiter, kinda recall reading something about it in the past..anyone else know anything??
Re: limited
Postby twail » Tue, 22 Mar 2011 9:04 +0000
Why wold you be gutted about that it would take you a long time to get to 135 in a mx5! And where would you ever do it?? You certainly won't do it on any track in Ireland.
And by the way it's 112mph not 115 ;)
twail
Re: limited
Postby Steve » Tue, 22 Mar 2011 10:27 +0000
have a look at the back of the speedo cluster, find the G / 180kph trace to a small screw and just remove it.
Re: limited
Postby leamyj » Wed, 23 Mar 2011 8:12 +0000
Steve wrote:have a look at the back of the speedo cluster, find the G / 180kph trace to a small screw and just remove it.
That's the one :thumleft:
Re: limited
Postby decoy » Thu, 24 Mar 2011 1:04 +0000
thanks for that. well apreciated
decoy
Re: limited
Postby 93 Mk1 » Fri, 25 Mar 2011 2:24 +0000
135 mph ? What model of MX5 is it ?
Re: limited
Postby decoy » Fri, 25 Mar 2011 3:40 +0000
97" originaly the slower 90bhp model, but the engine has been swapped for an older engine
decoy
Re: limited
Postby 93 Mk1 » Fri, 25 Mar 2011 7:23 +0000
Neither the 114 bhp NA6CE nor the 130 bhp 1.8 NA8CE will do 135 mph in standard form. Around 120 is their lot
really if you're lucky. The speedo will always read a little optimistic at the high end of the scale. A road test of the
1.6 in 1990 topped out at 116 mph.
Of course if your engine is not standard then it might be possible.
Re: limited
Postby decoy » Fri, 25 Mar 2011 9:49 +0000
hmm, thats probably it anyway.. it just felt as though the car could do more. as in it wasnt really struggling to reach the 112mph to start with
decoy
Re: limited
Postby barney » Fri, 25 Mar 2011 10:35 +0000
i was told that in japan eunos models were limited to 112mph/180kph
Re: limited
Postby 93 Mk1 » Sat, 26 Mar 2011 12:55 +0000
That's true - all home market cars in Japan are limited to 112 mph there (or at least were at that time). But even an unrestricted Eunos won't gain much speed
wise. It's just that law there dictates cars can't exceed 112 mph. Cars like Imprezas and Lancer Evo's really lost out as they were capable of far more.
