Adjustable cam ???
Adjustable cam ???
Postby Doc mx5 » Thu, 15 Mar 2012 11:43 +0000
Hi.i was told by the previous owner that my car had an adj cam in it.anyone ever her of it.and how do i adjust it.its a 94 1.8
i didnt ask him wen i was buyin it as i was in such a hurry to get out of there b4 he changed his mind about sellin it to me.(got it at a cheep price:))
thanks
Doc mx5
Re: Adjustable cam ???
Postby sidewaysreilly » Fri, 16 Mar 2012 8:19 +0000
he is probably on about a Vernier Cam Pulley. Nice if combined with a higher lift cam on the intake side. Worth about 7bhp if set up correctly. Really need to know what your doing tho if you start adjusting things.
Postby charged_rs » Fri, 16 Mar 2012 8:43 +0000
Doc mx5 wrote:Hi.i was told by the previous owner that my car had an adj cam in it.anyone ever her of it.and how do i adjust it.its a 94 1.8
thanks
take the cam cover off and have a look, post a pic or two on here and we can tell you who makes them and maybe find you some instructions too
If you dont know what you are doing with an adjustable cam , put the spanner down and step away from the car as there is a good chance you will fuck something up.
Postby franksm » Fri, 16 Mar 2012 9:05 +0000
Yeah, wouldn't be bothered with it. It'll let you tune the engine for high RPM (but then it won't idle or won't have any power whatsoever at low revs), or tune for low rpm (lots of low down torque but it won't be revvy at all. Not great for emissions either, all of this !
Postby Doc mx5 » Fri, 16 Mar 2012 10:13 +0000
Sound.thanks for all the info.ill take the rocker off an take afew pics and post them up in the nxt few days.i might b turnin the car into a track car so emmisions arnt an issue.thanks every one
Doc mx5
Postby sidewaysreilly » Fri, 16 Mar 2012 11:27 +0000
True Frank but will also let you set timing to what it should be also . Impossible with standard pulleys .
Postby Doc mx5 » Sat, 17 Mar 2012 1:52 +0000
Ill take afew pics temoro or sun.wat de you mean set the timing to what it should b
Doc mx5
Postby sidewaysreilly » Sat, 17 Mar 2012 3:05 +0000
Well, its a bit complicated if you dont understand cam timing in particular TDC Cam timing but this allows you to adjust the opening point of the inlet cam irrespective of the factory pulley/block marks to set the cam timing to the optimum when set against a disc fixed to the crank pulley.
The standard set up is good but combined with other mods particularly head work and different cams, it allows no adjustment to get the optimum whether it be mid range torque or holding onto torque higher up the rev range ( a screamer).
Vernier Pulleys allow you to do this. But, they are useless on a standard engine unless other mods are done. Fuel cut on mk 1's is 6900 and no amount of fiddling will get any more power above this.
Postby Doc mx5 » Sat, 17 Mar 2012 7:10 +0000
Ok.i wudnt really know much about that stuff.ill take afew pics in the morning if its not raining.i found this in behind the radio today.its alll hooked up.does anyone know what it is and how it works.thanks for all the help
Doc mx5
Adjustable cam ???
Postby mx5ash » Sat, 17 Mar 2012 7:43 +0000
It's a fuel controller, bit of info here
http://honda-tech.com/showthread.php?t=627124
Postby Doc mx5 » Sat, 17 Mar 2012 8:00 +0000
Cheers for that mate.i think im just gonna turn it off for time being.as ther are no lights coming up on the screen.maybe it not hooked up right.thanks
Doc mx5
Postby Doc mx5 » Sun, 18 Mar 2012 7:12 +0000
Doc mx5 wrote:Ill take afew pics temoro or sun.wat de you mean set the timing to what it should b
Doc mx5
Postby sidewaysreilly » Sun, 18 Mar 2012 7:23 +0000
Yeah, a very crude Vernier Pulley without the Vernier marks.
Postby charged_rs » Sun, 18 Mar 2012 8:38 +0000
thats a diy affair...and badly done at that
personally id scrap it and return it to standard...it would be interesting to see what deg timing your car is currently running
Postby Doc mx5 » Sun, 18 Mar 2012 9:52 +0000
Ok.so wats this mean.is it fu***d.should i get rid of it.is there anyone around the dublin area that could have a look at it.or how do i check the timing
Doc mx5
