Hi guys
All bulbs good and at the start it seemed intermittent
Any thoughts of what the issue would be?
Shena
LHS indicators all outHi guys
All bulbs good and at the start it seemed intermittent Any thoughts of what the issue would be? Thanks Shena "I am not only a pacifist but a militant pacifist. I am willing to fight for peace.
Nothing will end war unless the people themselves refuse to go to war" - Albert Einstein
![]() Re: LHS indicators all outHi Sheena'. Probably best o check fuses ar drivers knee area 'nust pop off the cover and each fuse should be marked on the inside of the cover. Only replace fuse if blown with one of same size ie 10 amp etc.I f it is blown and you do replace and it goes again there is a wiring fault or possibly bad connection at one of the indicator bulb holders. If you call me I can explain handier 086 8226506 Robert
LHS indicators all outHi Robert
Sorry should have said all fuses checked too Shena "I am not only a pacifist but a militant pacifist. I am willing to fight for peace.
![]() Re: LHS indicators all outOk well then possibly switch ,especially if opposite side is ok its hardly the flasher unit. Did u try the hazard lights to see if all indicators are working on hazard as this will eliminate some areas. If you ant me to look at it some evening I can try a few things
Re: LHS indicators all outHi Robert
hazzards not working but indicators flash when alarm turns on/off .. that's odd right but perhaps points to where the problem is? relay maybe? Shena "I am not only a pacifist but a militant pacifist. I am willing to fight for peace.
![]() Re: LHS indicators all outlooking like hazard switch but if you drop out we can try one.
I will get out to you some evening Thanks a mil Shena "I am not only a pacifist but a militant pacifist. I am willing to fight for peace.
