Clutch Judder in 1st & ReverseSince I got my car I have noticed a small judder when taking off in First or Reverse, the clutch seems fine otherwise but this judder is annoying. Is there anything I can check or look at to see whats causing it or do I have to go order a new clutch?
Re: Clutch Judder in 1st & ReverseGenerally you will need new clutch as the pressure plate is probably buckled but you could check the univ joints on the driveshagt for play/slack just in case.New clutch ( good quality) is around 150e plus labour approx 250e
Re: Clutch Judder in 1st & ReverseIf its not a standard clutch it can aswel my stage 3 does it the whole time
Re: Clutch Judder in 1st & ReverseThanks guys, I'm going to see if it gets any worse and then take the plunge and order a new one.
Re: Clutch Judder in 1st & ReverseCould it be the slave cylinder? Did you check that?
Re: Clutch Judder in 1st & ReverseBrakes could be another thing to check possibly?
Re: Clutch Judder in 1st & ReverseI haven't really checked anything major yet, the weird thing is that it is a bit sporadic so could be a leak on the clutch itself. But I'll try and get a look at the master cylinder as well.
Re: Clutch Judder in 1st & ReverseI have decided just to get the clutch done, the cheapest I have been quoted for just the clutch part is €250, that seems high. what you guys think?
Re: Clutch Judder in 1st & ReverseWe acn do full job incl all parts (4 parts plus oils etc) required for incl labour but I can save on parts if you want to use reconditioned (not recommended) 086 8226506
Thanks Robert, I have some meetings in Cork this week so need it done ASAP, I got a clutch for €200 and the garage next to me will fit it for €150. Well at least I don't have to worry about it for a while. The shopping list for this car this week has been astronomical (but mostly nice things), but I have to say it is looking pretty good now though....
Re: Clutch Judder in 1st & ReverseAh 350e all in is good price for complete job incl parts especially for NEW parts
