Diff/gearbox noise when slowing down
Postby Diarmuid » Mon, 07 Oct 2013 8:34 +0000
Hey lads, I've noticed over the last few days that I have this grinding/whirring noise when gearing down coming from the back either gearbox or diff. I found this link online and it pretty much sounds exactly like this:
http://www.google.ie/url?sa=t&rct=j&q=& ... GU&cad=rjt
Any ideas on how to fix this as its driving me mad. :cry: :cry:
Diarmuid
Re: Diff/gearbox noise when slowing down
Postby MX5Spares » Tue, 08 Oct 2013 12:02 +0000
Hi Diarmuid,have you replaced the clutch yet or is this a result from afterwards?? I know you bought a new clutch so is it fitted yet.If so and you did not have this noise beforehand ???? Maybe 350e WAS too cheap after all !!!
Postby Diarmuid » Tue, 08 Oct 2013 11:00 +0000
Yea its the new clutch but the clutch is a quality clutch, and I did over 400 miles this weekend in it so its only now when I got to test it properly so I can't be sure it wasn't there before
Diarmuid
Postby scallan » Tue, 08 Oct 2013 12:06 +0000
Is it on overrun amd bad in 5th gear could be ppf diff and gearbox wernt lined up heres a guide how to if it is
http://www.mx5nutz.com/forum/index.php?showtopic=55139
scallan
Postby rhysmate » Tue, 08 Oct 2013 2:00 +0000
i agree with the above, it happened on mine before i adjusted the ppf after i changed the gbox
Postby MX5Spares » Tue, 08 Oct 2013 5:15 +0000
Looks like thta might be the issue alright.Also check exhaust heat shields are all tight and no rusty brackets etc as they rattle badly especially ay certain revs etc
Postby Diarmuid » Tue, 08 Oct 2013 8:08 +0000
HHMM I don't have the tech to check that out, do you know someone around that I can get to check this out?
Diarmuid
Postby MX5Spares » Tue, 08 Oct 2013 8:11 +0000
We can check it for you if you come out before friday but car ramp busy all day Saturday and Sunday...biggish job in !!
Postby Diarmuid » Thu, 10 Oct 2013 5:49 +0000
So poped out to Robert (autocheck) and we adjusted the PPF which was out, found some loose exhaust components all sorted now except none of them were the problem. I wonder if the spigot baring could be the cause, I completely forgot about it until after the clutch was done :roll:
Diarmuid
Postby MX5Spares » Thu, 10 Oct 2013 8:46 +0000
Whoever done the clutch should have checked it at least!! If it is bad its gearbox out again!!
Postby Diarmuid » Thu, 10 Oct 2013 9:28 +0000
Agreed Robert, this car is throwing up a few surprises, got 4 new tyres fitted to the new (well new to me) ASA 17" rims today and told them to do the camber,tow and tracking as well. It turns out that it was off the scale in the back. But every bit I do is one bit less I guess.....
Diarmuid
Postby MX5Spares » Fri, 11 Oct 2013 7:20 +0000
Well your getting there and finding things wrong is good....at least you can fix them then.Tracking,camber etc now being corrected will make major difference to overall drive!! So me oul level was,nt that far off all the same !!!! "The oul ways are the best me laddie"...well nearly anyway
Postby Supertoucher » Sun, 13 Oct 2013 11:19 +0000
Can I ask exactly how you adjusted the PPF?
Mine does this, usually on overrun, or on sudden acceleration.
Thanks in advance
2001 JDM Mk2.5 RS 6 Speed
Supertoucher
Postby sidewaysreilly » Sun, 13 Oct 2013 6:19 +0000
Steve posted a drawing of it some time back........
Postby Steve » Sun, 13 Oct 2013 10:43 +0000
Put a flat edge across the chassis rails and measure A, then adjust if needed.
