Delete
Tue, 07 Jan 2014 7:16 +0000
by MX5Spares
Delete
Re: diff identity by number on crown wheel 1245
Tue, 07 Jan 2014 8:08 +0000
by scallan
Did you try count the teeth on the crown wheel and pinion?
Tue, 07 Jan 2014 9:18 +0000
by MX5Spares
Not yet but is it as simple as counting the teeth on the crown wheel per revolution ???
Tue, 07 Jan 2014 9:28 +0000
by scallan
Are you wanting the diff ratio?? Count teeth on the crown wheel and then count teeth on pinion and divide first number by second
Wed, 08 Jan 2014 2:55 +0000
by MX5Spares
I knew it was something like that but thanks that's easy .!!
Wed, 08 Jan 2014 7:45 +0000
by sidewaysreilly
Dead easy, turn the input flange and count how many revolution it takes to rotate the output /shaft side one revolution.
