Page 1 of 2
timing belt costs
![Post Post](./styles/aero/imageset/icon_post_target.gif)
Sun, 12 Jan 2014 10:56 +0000
by fez
How much should I expect to pay for a timing belt to be done on a mk1 1.6? What else is worth doing while it's being done such as water pumpy bits?
Re: timing belt costs
Mon, 13 Jan 2014 7:29 +0000
by MX5Spares
Hi Fez the waterpump should be replaced with the timing belt incl the two pulleys also .The pump and timing belt kit are about 130e plus labour about 150e.I can do it for you if you want .
Mon, 13 Jan 2014 11:36 +0000
by fez
Sounds good. The belt that drives the power steering snapped the other day (hence why I decided I best change all the belts). What else runs from that belt? If the alternator or water pump do i'd have to get it towed obviously. Just googled, seems to be the Ps and ac, should it be ok to drive, provided I don't do any 3 point turns?
How many fecking belts does this engine have????
Tue, 14 Jan 2014 8:00 +0000
by MX5Spares
Ah its ok to drive just very heavy steering and no AC.
Tue, 14 Jan 2014 10:44 +0000
by Randy
autocheck wrote:Ah its ok to drive just very heavy steering and no AC.
This. Had to drive around for a day like this. Bit annoying in the steering, but doesn't do any damage.
Tue, 14 Jan 2014 5:37 +0000
by fez
for the timing belt, should I get a rocker cover gasket too?
Tue, 14 Jan 2014 6:30 +0000
by fez
also for the crankshaft seal, how do i know which engine I have? It's a 92 jap import, but the engine could have been changed before I bought it.
Tue, 14 Jan 2014 7:38 +0000
you mean short or long nose crank?
Tue, 14 Jan 2014 8:51 +0000
by fez
Tue, 14 Jan 2014 9:30 +0000
by Randy
fez wrote:for the timing belt, should I get a rocker cover gasket too?
I got a gasket too, and I'm having the timing belt kit, pump, pulleys, and gasket all being done at once.
Peace of mind.
Tue, 14 Jan 2014 9:55 +0000
by MX5Spares
Fez oil seal can be replaced at same time its only about 10e for seal
Tue, 14 Jan 2014 11:16 +0000
by fez
Randy wrote:fez wrote:for the timing belt, should I get a rocker cover gasket too?
Peace of mind.
Where'd you get it from? Looking for the best value
Tue, 14 Jan 2014 11:51 +0000
by fez
Steve wrote:you mean short or long nose crank?
Yeah, in the link above theres either 4 or 8 slots, so its short or big nose crank. Seems the short one was only in production for the first year yeah?
Wed, 15 Jan 2014 12:59 +0000
by Randy
fez wrote:Randy wrote:fez wrote:for the timing belt, should I get a rocker cover gasket too?
Peace of mind.
Was looking at mx5parts, but wouldn't have them in stock for another 3-4 weeks..
http://www.ebay.ie/itm/171175014942?ssP ... 1497.l2649http://www.ebay.ie/itm/400582627689?ssP ... 1497.l2649
Wed, 15 Jan 2014 8:18 +0000
by MX5Spares
That's second picture is a head gasket not cam cover but the Continental kit looks good and quality is great .Is it much cheaper then Ireland at about 130e??
