removing diff from ppf
Postby Merlot man » Sun, 26 Jan 2014 6:39 +0000
Hello all
I'm in the process of refurbing the rear subframe on my 99 nb and trying to remove it from the car .All going ok until I try to remove the diff[ torsion lsd I think] from the rear of the ppf .
The bolts and the collar on the bottom came out ok and everything is loose but it won't move out from the top .
There are two "spacers" on the top and bottom ,I've loosened the bottom one but there seems to be a sleeve on one of the bolt holes holding it in and there is no movement on the top one ,rods book says it should move sideways out of the way but this is not happening for me.
Any ideas or am I going about this the wrong way.[I knew it was all going too smoothly ! ]
Thanks in advance
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: removing diff from ppf
Postby scallan » Sun, 26 Jan 2014 6:53 +0000
Take it off from thw gearbox and then you will be able to remove the ppf while the diff is away from the car. Works for me
scallan
Postby MX5Spares » Sun, 26 Jan 2014 10:02 +0000
Hi Briam .did you tap up the locking nuts .Baasically leave the ppf frame bolts in and at up the splined nuts while the bots are still threaded,they pop out at the top as the nuts are on splines
Postby Steve » Mon, 27 Jan 2014 6:10 +0000
yep, thats the one, screw them back in a bit and tap the heads.
Postby Merlot man » Mon, 27 Jan 2014 9:24 +0000
Thank you all for the prompt replies
I was going to do your idea Scallan but might try Roberts idea first, seems a bit simpler .
Thanks again
Brian
93 na s ltd
Merlot man
