Can anyone give me any advice on where to get one or if there are other alternatives? (would ideally like an lsd)
1.8 Torsen DiffHey I'm just new to this forum and am needing some advice about diff's. I recently got myself a 1.6 1997 mx5. But it has a welded diff
Can anyone give me any advice on where to get one or if there are other alternatives? (would ideally like an lsd) Thanks
Re: 1.8 Torsen DiffWe have some LSD from time to time but just sold two last week.Be careful to get correct diff as some are open diffs and you need to be able to spot the difference.Give me a call if you want info or any parts as we break mx5,s in Dublin,thanks Robert 086 8226506
Re: 1.8 Torsen DiffWould you need to change the shafts then for the LSD and how difficult is it to change?
Re: 1.8 Torsen DiffDepends which car you have. If its 1.6 you will definitely need all three shafts and if its 1.8 you wont need any shafts.Your existing will fit
Re: 1.8 Torsen DiffIt's a 1.6, so I could only get away with putting a 1.6 lsd in it without changing the shafts?
Re: 1.8 Torsen DiffYeah ,but you wont get one.!!
