What Clutch
What Clutch
Postby ger » Sun, 13 Apr 2014 4:05 +0000
Ahhh clutch started slipping at peak torque. oddly it grabs again after about 1000rpm and pulls to redline so I guess its on the way out, very annoying. I suspect it maybe contaminated from the rear main seal as I only have about 30K on it.
Anyway I have an exedy stage 1 at the moment, feels nice, little stiffer than stock but I'm not sure how much abuse it can take. Looking at one of these but open to advice. Spec is 1.6 turbo @ 8psi dont have exact figures at the mo but approx 200bhp and 160-170 lbs
http://www.mx5parts.co.uk/clutch-exedy- ... -1808.html
or else get a 1.8 flywheel and one of these
http://www.mx5parts.co.uk/clutch-exedy- ... -1806.html
not sure what the pros and cons are. any other suggestion/options.
Re: What Clutch
Postby Fergus » Sun, 13 Apr 2014 9:54 +0000
I'd get a lightened flywheel, the Stage 2 clutch and never look back :mrgreen:
Re: What Clutch
Postby MX5Spares » Mon, 14 Apr 2014 6:55 +0000
1.8 is way better clutch set up .
Re: What Clutch
Postby ger » Mon, 14 Apr 2014 9:12 +0000
Thanks fergus, not sure I need a light flywheel with the turbo engine, it spins up pretty quickly already.
Are puck clutches worse for daily driving, chatter etc?
I'm leaning towards option 2 1.8 stage 1 and 1.8 flywheel at the mo but very much open to suggestions
Robert, if I was taking a flywheel as PM'd what would the labor cost be for the clutch change? I would supply clutch and spigot bearing. If you want to PM me the total.
Re: What Clutch
Postby [L'e$kro] » Fri, 18 Apr 2014 3:22 +0000
I have a brand new 1.6 paddle clutch disc if it's any interest for you?
The paddle clutch will have more byte, the downside is that the slipping range is narrower, the upside being that it will hold more torque than organic without having to resort to a stiffer spring mechanism.
Nico
[L'e$kro]
Re: What Clutch
Postby rhysmate » Fri, 18 Apr 2014 3:35 +0000
I have a 1.8 machined flywheel and Exedy stage two ouck clutch, and i love it. feels normal and grips well (14 psi)
Re: What Clutch
Postby Fergus » Fri, 18 Apr 2014 9:35 +0000
A 1.8 clutch won't handle above 8PSI (165BHP+) and will burn out.
Re: What Clutch
Postby [L'e$kro] » Sat, 19 Apr 2014 9:15 +0000
Not good news for me then...
I run 8psi on the standard 1.6 clutch which doesn't have much clamping force, and was hoping the standard 1.8 one would be just fine as the pedal is stiffer on them. But then with more boost and longer diff, I might have to find something else..
Nico
[L'e$kro]
Re: What Clutch
Postby Fergus » Sat, 19 Apr 2014 11:09 +0000
Yeah, once you hit 8PSI+ things start burning up - clutch, diff, bank account.
Re: What Clutch
Postby MX5Spares » Sun, 20 Apr 2014 6:43 +0000
Check out mx5 nutz as there is similar clutch conversation going on there at moment and general advice is good 1.8 clutch as heavy racing clutches are expensive, uncomfortable and not really for road use. Some lads on there also have paddle clutch but not for road use also.
Re: What Clutch
Postby ger » Sun, 20 Apr 2014 7:37 +0000
[L'e$kro] wrote:Not good news for me then...
Nico
my stock clutch started slipping above 6psi and that was a low mileage exedy std 1.6 clutch. I thought the stock clutch was only rated at 140lbs torque on a good day.
I get a boost spike on quick throttle up to 10psi then settles at 8psi to redline, this gives a nice little kick on acceleration.
The exedy 1.6 stage 1 i have in now has been holding power fine at 8psi and 170hp (200bhp) for a few years now and I no suspect its getting slightly contaminated from the rear main seal.
[L'e$kro] wrote:I have a brand new 1.6 paddle clutch disc if it's any interest for you?
Nico
Is this just the disc or complete kit? What brand?
Re: What Clutch
Postby scallan » Sun, 20 Apr 2014 10:44 +0000
I have a paddle clutch and dont find it bad at all. My car is still na but i give the clutch a fair bit of abuse which it takes no bothers oh and its a f1 racing clutch fairly cheap and no problems in nearly 2 year.
scallan
Re: What Clutch
Postby [L'e$kro] » Mon, 21 Apr 2014 8:44 +0000
autocheck wrote:Check out mx5 nutz as there is similar clutch conversation going on there at moment and general advice is good 1.8 clutch as heavy racing clutches are expensive, uncomfortable and not really for road use. Some lads on there also have paddle clutch but not for road use also.
Thanks for the suggestion Robert.. I'll have a look there. I drive the mx5 everyday and often sit in traffic, and while a cera-metallic clutch isn't that bad, i'd rather keep an organic one if possible.. On the other hand I'm not too keen on experimenting too long with this as taking the gearbox out is a fiddly job and Id rather not do it every week, so throwing something beyond requirement is also tempting.
ger wrote:my stock clutch started slipping above 6psi and that was a low mileage exedy std 1.6 clutch. I thought the stock clutch was only rated at 140lbs torque on a good day.
Clutches can sometimes last over what they are rated for, I know a lad running a 500hp/600nm Citroen AX drag car and he runs a single AP Racing disk which is rated for less than 400nm.
I have 8.5psi maximum boost now, and it holds OK as the boost rises quite progressively (big exhaust housing on the turbo) and as I still have a 4.3 standard diff.
Now of course if I flat-shift on dry surface in high gears it kills the clutch instantly.
ger wrote:Is this just the disc or complete kit? What brand?
It's just the disc, and the brand is XTD
Nico
[L'e$kro]
Re: What Clutch
Postby Fergus » Mon, 02 Jun 2014 12:43 +0000
"Now of course if I flat-shift on dry surface in high gears it kills the clutch instantly." - Well, there you go ?
"The exedy 1.6 stage 1 i have in now has been holding power fine at 8psi and 170hp (200bhp) for a few years now and I no suspect its getting slightly contaminated from the rear main seal." - Well, there you go ?
Get it right the first time and walk away :wink:
