Gearoil change in a 6 speed box
Postby Merlot man » Thu, 01 May 2014 9:41 +0000
Hello all ,
Im looking at this job and was wondering where the filler and drain plugs are on the 6 speed ,there seems to be alot of torx bolts on the gearbox .
I've done it on the 5 speed before and the plugs are easy to find ,last thing i want to do is unblot the wrong bolt and the box to blow up!
Any advice /pictures would be great .
Thanks in advance
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: Gearoil change in a 6 speed box
Postby [L'e$kro] » Thu, 01 May 2014 12:02 +0000
You can fill up the gearbox from the turret/shifter, it's way easier than on the 5 speed!
Nico
[L'e$kro]
Postby Merlot man » Thu, 01 May 2014 3:06 +0000
Thanks Nico ,Deivis told me the same thing and that makes complete sense .
I am assuming it takes 2l of gear oil ?
Brian
93 na s ltd
Merlot man
Postby [L'e$kro] » Thu, 01 May 2014 3:49 +0000
Yes, they say 2 quarts in the US, so 2 bottles of 1l
Nico
[L'e$kro]
Postby MX5Spares » Thu, 01 May 2014 4:50 +0000
Brain ,I have a workshop extract page and be careful as the filler cap is tricky.If you remove the wrong one you will lose 5th and reverse gear and box has to be stripped and refitted as some spring etc drops in to box........11Warning!!!
Postby Merlot man » Fri, 02 May 2014 11:36 +0000
That is what I was afraid of Robert but I assume that filling it from the top through the turrent will be safer ?
Where is the drain plug, I know it must be on the bottom! I was told by Dievis that its a 22/3 mm normal hex bolt and NOT any of the torx bolts .Is this correct?
Thanks in advance
Brian
93 na s ltd
Merlot man
Postby [L'e$kro] » Fri, 02 May 2014 11:58 +0000
Have a look there Brian, there are pics:
http://www.miata.net/garage/6mt_fluid/
Nico
[L'e$kro]
Postby rhysmate » Fri, 02 May 2014 12:21 +0000
Couldn't resist
Postby [L'e$kro] » Fri, 02 May 2014 12:23 +0000
Good one Rhys :D
[L'e$kro]
Postby davith501 » Fri, 02 May 2014 12:27 +0000
That's a very good guide. Wouldn't mess with any plastic hoses tho. Fill through gear lever turret..less mess and gives you a chance to check dust boots as they seemingly don't last very long.
Deivis
Icon
RS
Mk1
davith501
Postby Merlot man » Fri, 02 May 2014 4:06 +0000
Thanks lads for all the advice .......even you Rhys :D
Filling through turrent seems like a neat way.
Brian
93 na s ltd
Merlot man
