Oil on Spark Plugs
Oil on Spark Plugs
Postby Mike » Sun, 25 May 2014 10:06 +0000
Engine started misfiring occasionally on my 92 Mk1, changed the spark plugs and found oil on three of the spark plugs on the sparking side of the plug. Still misfiring with new plugs. Do I have major engine problems?
Mike
Re: Oil on Spark Plugs
Postby Yolo » Sun, 25 May 2014 11:19 +0000
Not an expert but from what I have read this sounds more like a leaking cam gasket seal which is an easy fix but I am sure someone else here will confirm or correct me.
1992 Mk1 Eunos silver
Mk2 suspension
IL Motorsport bushes
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
http://www.mazdamenders.net
Yolo
Postby Steve » Mon, 26 May 2014 12:14 +0000
its the first thing I'd check too.
Postby Mike » Mon, 26 May 2014 8:02 +0000
Thanks, I will do that next.
Mike
Postby MX5Spares » Mon, 26 May 2014 4:59 +0000
Use genuine Mazad gacket only not spurious ones as they tend to leak even though they physically look the same.There is only about 5e in the difference anyway.Dealers only
Postby Mike » Tue, 27 May 2014 5:14 +0000
Thanks Robert
Mike
Postby Fergus » Tue, 27 May 2014 10:15 +0000
And don't forget about the liquid gasket on the six spots and torque the bolts up correctly or it will be leaking everywhere !
http://www.miata.net/garage/valvecover/index.html
Postby MX5Spares » Wed, 28 May 2014 5:09 +0000
Small amounts only of sealer at 6 points.I have had two mx5,s in last month both seized from silicone in sump.Done by some other garages somewhere but both identical issues,jumping oil pressure ,and seizure.!! Be Warned.!!
Postby Steve » Thu, 29 May 2014 11:29 +0000
did it clog the oil pickup?
Postby Yolo » Thu, 29 May 2014 12:54 +0000
I have seen a lot of debate on the use of sealant on other sites so I didn't use it just the OE seal and have had no problems....
Mk2 suspension
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
Yolo
Postby Fergus » Mon, 02 Jun 2014 12:50 +0000
Yolo wrote:I have seen a lot of debate on the use of sealant on other sites so I didn't use it just the OE seal and have had no problems....
Then just wait for the oil leak at the back of the block that will cover your entire engine & bay area :shock:
Postby davith501 » Mon, 02 Jun 2014 7:35 +0000
That happened to me. I used a non oem gasket. Lesson learned.
Deivis
Icon
RS
Mk1
davith501
Postby MX5Spares » Mon, 02 Jun 2014 8:07 +0000
Yes both engines with oil pressure issues and when I took sump off loads of silicone floating around but that was after two seperate ggarages sealed the cam cover ALL THE WAY AROUND with silicone,not just the corners.Minimal amount at the 6 spots only if any at all !!
Postby Yolo » Mon, 02 Jun 2014 11:38 +0000
Fergus I am a year down the line and not a drop to be seen, all dry as a bone thank god and long may it last.... :D
Mk2 suspension
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
Yolo
