New member issue
Thu, 25 Sep 2014 4:39 +0000
by Bryson
Hi Guys,
Two issues with me firstly, I have a Mk3 and I live in Belfast. I hope you don't hold that against me......
I am getting a slight engine 'noise' from my mk3 which sounds like a slapping/tapping. When the engine is cold you cannot hear it. It seems to be only when the engine is hot. I don't think its the lifters as it only happens when the engine isn't under strain i.e. not accelerating or decelerating but feathering the throttle at about 3000rpm. I'm thinking its the cam chain slapping about. The car was a bit low on oil when I bought it too. I've hear that it is related.
Cheers!
Re: New member issue
Thu, 25 Sep 2014 4:41 +0000
by Bryson
I forgot to mention its a 2.0l
Thu, 25 Sep 2014 5:17 +0000
by MX5Spares
Hta eto be bearer of bad news but mk3 mx5 are well known for engine problems.
Thu, 25 Sep 2014 5:46 +0000
by Bryson
Awesome
Thu, 25 Sep 2014 8:01 +0000
by Yolo
Hi Bryson they shouldn't hold being from belfast against you as they let me tag along with them on a run and a good bunch they are too.... There is a guy in comber (I think) that works on these, a mate used him recently, and he might be able to help out if you want me to see if I can get a number.
Thu, 25 Sep 2014 8:14 +0000
by andrew
Bottom ends go on these if run low on oil. All you can do is drive it on and hope for the best.
Fri, 26 Sep 2014 11:20 +0000
by Bryson
Cheers for your help gents. Yolo, that number would be great.
Fri, 26 Sep 2014 11:02 +0000
by Yolo
Bryson wrote:Cheers for your help gents. Yolo, that number would be great.
Ok will give my mate a sout tomorrow and see if he has a number for him. Will keep you posted..
Sat, 27 Sep 2014 7:57 +0000
by MX5Spares
Get the noise checked out as it may do more damge and engines for these are scarce ,like 1k .used .It may be something simple
