How Much Fuel Do You Use?
Postby Eoghanb123 » Sat, 19 Sep 2015 3:28 +0000
I'm curious as to how much petrol you guys go through. I get about 18MPG which is about 131 miles out of €40, give or take a few miles depending on the fuel prices. I'm just wondering what you guys get.
I do about a 40%/60% spilt between rural/urban.
Eoghanb123
Re: How Much Fuel Do You Use?
Postby KevC » Sat, 19 Sep 2015 4:28 +0000
In my NA I'm getting a pretty consistant 27MPG which is mostly city driving. On the motorway, I can achieve up to 36.
KevC
Postby scallan » Sat, 19 Sep 2015 5:45 +0000
I put petrol in it when it needs it.... same with the pajero fill it up every week never really bothered about mpg as i need to get from a-b in the jeep and fun cant be measure in mpg in a mx5.
scallan
Postby Eoghanb123 » Sat, 19 Sep 2015 7:41 +0000
scallan wrote:I put petrol in it when it needs it.... same with the pajero fill it up every week never really bothered about mpg as i need to get from a-b in the jeep and fun cant be measure in mpg in a mx5.
Oh I'm the same I was just curious as to what other people get! It's my daily and only car so it's hard not to notice! No complaints though!
Eoghanb123
Postby AndyJF » Sun, 20 Sep 2015 11:30 +0000
First thing I'd check is the lambda as it seems to be everyone's first port of call with bad mpg. Also short trips are going to be really bad for MPG. A cold engine can take up to 60% more than one fully up to temperature.
Sent from my A0001 using Tapatalk
AndyJF
Postby 93 Mk1 » Sun, 20 Sep 2015 1:59 +0000
On average, I get around 29/30 mpg or a tad less if driving harder. (1.6 NA).
93 Mk1
Postby gasha » Sun, 20 Sep 2015 3:25 +0000
Doing a 240 mile round trip not crossing 60mph and behaving myself going through the gears I get 39mpg in 1.6 NA and 34mpg in 1.8 NA.
Good returns but no fun.
92 S Special Black
94 RS Limited Montego Blue
89 Roadster Silver
gasha
Postby Eoghanb123 » Sun, 20 Sep 2015 3:52 +0000
I might only get 18 MPG but I can safely say I do so with a huge grin on my face!
Eoghanb123
Postby TOM 5252 » Sun, 20 Sep 2015 8:47 +0000
A couple of months ago I drove from east Donegal to Drogheda and back to view red mk3. Most of the trip was done at maximum legal speed including the motorway sections. The MPG. for the run was 41.4, my usual mpg for this 16 year old mk2 is 37 or 38 (weekend driving , shopping trips etc).
That Drogheda trip was before I replaced both rear lower wishbones, marking and re-assembling the cam bolts. According to my NCT report a year ago the front axle slide-slip was -5.0 and rear was +0.2,
The NCT test-passed yesterday with no problems, reports front axle slide-slip is now -4.0 and rear is +7.1, so I might have to get the tracking done again, even though the handling has not felt any different since I fitted the wishbones from autocheck.
The point of the previous paragraph is that when I googled Side-slip last night to see how it relates to toe-in etc. I discovered that high side-slip values have a big effect on tyre and fuel usage. The nearer to zero you can keep these readings then the less fuel and rubber you waste in normal driving.
Also possibly relating to MPG ? according to yesterday's report my engine is running better than last year.
Last year's emissions figures-- idle CO 0.15 HC 69 fast CO 0.07 HC 39
This year's emissions figures-- idle CO 0.01 HC 16 fast CO 0.03 HC 26
Maybe at 46,000 miles the engine is only now fully run-in !
Tom 5252
TOM 5252
Postby sidewaysreilly » Sun, 20 Sep 2015 11:49 +0000
what mileage (kilometerage!) per tankfull are we all getting?
Postby 93 Mk1 » Mon, 21 Sep 2015 9:00 +0000
I think I get somewhere around 480 kms but it's been a while since I checked.........(must do some longer trips again !).
93 Mk1
Postby emarkey » Tue, 22 Sep 2015 10:15 +0000
Im getting 11.5mpg atm.
emarkey
Postby andrew » Thu, 24 Sep 2015 9:09 +0000
About 350km per tank for me
andrew
Postby sidewaysreilly » Sat, 26 Sep 2015 5:21 +0000
Got 350kms for the last 50euro worth. That was on the run up north too so happy considering its at 12psi.
