Power Steering Fluid use?
PostPosted: Fri, 25 Sep 2015 9:55 +0000
by gary k
Since I've started drifting I've noticed that my power steering fluid reservoir always boils over and from what I gather it is a common occurrence in the MX5s after some "spirited" driving. I have been recommended to using the Red Line Power Steering Fluid as it is supposed to be much more durable and heat resistant. Has anyone on here used it or would I be better just getting a power steering fluid cooler or just remove the power steering altogether?
Also, if I were to use the Red Line fluid, does anyone know how much power steering fluid an MX5 takes?
Re: Power Steering Fluid use?
PostPosted: Fri, 25 Sep 2015 2:48 +0000
by scallan
I removed it all together on my track car and im considering doing it with the road car aswel as it boils the odd time but suppose its up to ur own prefrences
PostPosted: Fri, 25 Sep 2015 4:17 +0000
by gary k
Did you find much difference on the track with and without powersteering?
Also did you put in a manual rack or did you just depower your own rack?
PostPosted: Fri, 25 Sep 2015 4:38 +0000
by scallan
Depowered my own rack as manual is a longer rack turn to turn. Eh i found it grand out on track bit of hardship turning at 1mph but once you get going its grand
PostPosted: Fri, 25 Sep 2015 8:07 +0000
by gary k
I read a couple of different ways people depower it, is it a fairly simple job?
PostPosted: Fri, 25 Sep 2015 8:33 +0000
by scallan
I followed miata.net guide i think. Took the rack apart and done it that way. Also you have to weld the pinion which is not in that guide but in some of the others
PostPosted: Sat, 26 Sep 2015 11:33 +0000
by gary k
Must have a look at it, thanks a million!
PostPosted: Sat, 26 Sep 2015 5:12 +0000
by sidewaysreilly
Put a small oil cooler in the pipe. Sorted.
