by MX5Spares » Sun, 29 Nov 2015 8:27 +0000
Hi James, I have been told its easy enough.Fit the mk1 wiring and fuel lines /injector rail etc as mk2 is different.Also put your own CAS sensor in to mk2 head.If I remember correctly I think the manifolds are higher up on the mk2 head for better flow etc so thet might leave your front ex pipe needing extension??Also the mk2 has 4 into 2 into 1 ex manifold and mk1 is usually 4 in to 1 so you will have to weld in section etc.Bottom end is same really.Both are still BP series engines anyway.
