diff oil leak ?
diff oil leak ?
Postby Merlot man » Mon, 30 Nov 2015 11:17 +0000
Hello all .
I 'm in the middle of taking the rear sub frame out of my mk1 fitted with a later torsan diff ( i think).
The frame , ppf ,under body etc are wet so I'm assuming that the diff is leaking , so my question is how big a job is it to replace the three oil seals , also is there a gasket /seal between the diff and the housing or is it liquid gasket that's used there .
Any advice would be great
thanks in advance
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: diff oil leak ?
Postby Steve » Mon, 30 Nov 2015 4:21 +0000
liquid gasket for the housing and the side (axle) seals are a push fit as far as I remember
Re: diff oil leak ?
Postby MX5Spares » Mon, 30 Nov 2015 6:11 +0000
Hi Brian , confirmed as Steve says
Re: diff oil leak ?
Postby Merlot man » Mon, 30 Nov 2015 6:54 +0000
Thanks lads , that's what I figured
What happens at the front seal, it seems to be a more involved job ?
I must also check and clean the vent on the top ,I'm hoping it's just it that's blocked :D
I'm assuming wd40 is the correct cleaner to use ?
That's for the advice
Brian
93 na s ltd
Merlot man
Re: diff oil leak ?
Postby MX5Spares » Mon, 30 Nov 2015 7:20 +0000
Front seal is complicated.You have to strip the bearing and then fit new crush washer and torque to correct setting.It adjust the backlash on the diff so it will bust if its too tight and very slack diff if its too loose.The washer only crushes once so new washer needed every time.Messy.Its specialist job to set up correctly
Re: diff oil leak ?
Postby Steve » Wed, 02 Dec 2015 2:02 +0000
yeah... messy, involves shims too.
Re Vents, wasn't I supposed to pick up 2 of those a while back? :-)
Anywho, I think what happened was that I read that they can be cleaned out with a spray of brake cleaner and they'll be good to go again.
Re: diff oil leak ?
Postby Merlot man » Wed, 02 Dec 2015 5:39 +0000
Ya I think that was one of the plans :D , I removed it and cleaned it out with plenty of wd40
When I released it from the housing it let off some air pressure so that could be my problem , pressing the gear oil out ?
What do people think ?
Brian
93 na s ltd
Merlot man
Re: diff oil leak ?
Postby MX5Spares » Wed, 02 Dec 2015 6:09 +0000
Hi Brain, must be the vent blocked as there should not be pressure in the diff.Fit the side sela s and clean the vent and refit it.
Re: diff oil leak ?
Postby Merlot man » Wed, 02 Dec 2015 7:09 +0000
Thanks Robert ,ya that's the plan all right .
How difficult is it to remove the half shafts from the Torsan ?
Brian
93 na s ltd
Merlot man
Re: diff oil leak ?
Postby davith501 » Wed, 02 Dec 2015 8:35 +0000
Once the bolts are undone, think they just slide out, Brian. Little pray bar might help.
Icon
RS
Mk1
davith501
Re: diff oil leak ?
Postby Merlot man » Wed, 02 Dec 2015 10:32 +0000
Thanks Dave but is that not for the 1.6 mk1 diff ,this car has a 1.8 mk1/2 lsd fitted so the half shafts aren't bolted on , they are simply slotted into the diff .
I've used a couple of pry bars on them but I'm afraid of using too much force in case I Damage the housing or the shaft end .
Am I simply being too much of a sissy ! :-o :shock:
Thanks for the replies
Brian
93 na s ltd
Merlot man
Re: diff oil leak ?
Postby davith501 » Wed, 02 Dec 2015 10:40 +0000
It could be .. Haven't been under the car for some time now. Sure if there's no clip some sort under the rubber just give it a tug and should come out I think.
Icon
RS
Mk1
davith501
Re: diff oil leak ?
Postby scallan » Wed, 02 Dec 2015 11:50 +0000
Just put in a pry bar and they will just pop out of diff. Might be an idea to take the bolts out of both rear wheel hubs so you can pull the shafts away from the diff to tap in the seals
scallan
