NCT Emissions fail
NCT Emissions fail
Postby Farasbarr » Fri, 11 Dec 2015 8:44 +0000
1992 Import Eunos 1.6
Readings Limits
Low Idle CO 8.58 VOL% above 3.50%
(840rpm) HC 458ppm above 750ppm
Well guys, car failed on CO with colours the other night and I'm hoping ye can help. Looking around here on other threads, someone else had similar reading and someone pointed out that it could be a air flow/MAF sensor problem. Is there a way of testing these parts rather than just getting a second hand one and chancing it for another NCT only to fail again? Over the weekend I'm hoping to try test my lambda with the multimeter test and the cat using the thermometer test so I can source parts that I do need before Christmas holidays make that impossible before my retest date passes. All help is greatly appreciated. Thanks
Farasbarr
Re: NCT Emissions fail
Postby MX5Spares » Sat, 12 Dec 2015 6:53 +0000
We have whatever bits you need when you find out exactly whats wrong. 086 8226506.Here over Christmas most days
Postby sidewaysreilly » Tue, 22 Dec 2015 1:02 +0000
what was the lambda reading ?
All components can be checked for output values and should be to eliminate the good ones.
