Torsan lsd. ?
Torsan lsd. ?
Postby Merlot man » Tue, 19 Jan 2016 11:11 +0000
Hello all
I'm in the middle of work on my mk1 which I understood was fitted with a Torsan lsd but I've taken it out of its housing and it looks to me that it may be open :evil:
Does anyone have a photo of what a Torsan looks like inside , no point in doing donuts or spinning on grass and Tarmac as the car is in pieces !
Thanks in advance
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: Torsan lsd. ?
Postby Piers14 » Wed, 20 Jan 2016 1:21 +0000
Here is a Mk1 Torsen.
Piers14
Re: Torsan lsd. ?
Postby elte1000 » Wed, 20 Jan 2016 9:16 +0000
Hi, here is how mine look like.
elte1000
Re: Torsan lsd. ?
Postby Steve » Wed, 20 Jan 2016 12:22 +0000
Re: Torsan lsd. ?
Postby Merlot man » Thu, 21 Jan 2016 9:56 +0000
Hello all and thanks very much for your input
I've had some advice from Robert McGuire and it looks like I've an open diff ....ahhhhhhh
I'm going to try and upload a picture so you all can see
Thanks again
Brian
93 na s ltd
Merlot man
Re: Torsan lsd. ?
Postby Piers14 » Thu, 21 Jan 2016 10:06 +0000
Yep, Looks like an open diff...
Piers14
Re: Torsan lsd. ?
Postby Real Rayzor » Fri, 22 Jan 2016 2:10 +0000
Can someone explain to me the difference between the diff's available.
Real Rayzor
Re: Torsan lsd. ?
Postby Piers14 » Fri, 22 Jan 2016 3:26 +0000
Quick one..
1. Open diff (1.6, 1.8 MK1, 2 & 3)
2. Viscous diff (Mk1 & Mk2 1.6) Has limited locking potential and with age gets less effective (only useful on the road to slightly improve rear traction)
3. Torsen 1(Mk1 1.8 ('94 - '98) Major improvement over viscous and very forgiving (good for road & motorsport)
4. Torsen 2 (Mk2 1.8 ('98 - '00) Modified to make production simpler, doesn't have as good a pre-load (i.e. will not lock the wheels together as much for improved traction)
5. Tochigi Fuji Sangyo Super-LSD (Mk2.5 (2000 - 2005) More money saving I'd say. This is a metal cone 'clutch' system and a proper POS (Ok for road, no real use in motorsport)
Piers14
Re: Torsan lsd. ?
Postby Real Rayzor » Sun, 24 Jan 2016 2:52 +0000
Thanks for the explanation piers14. So what's the best all round diff then. What do we all want or does it vary if you use your car for road only or if you do some track time.
Real Rayzor
Re: Torsan lsd. ?
Postby Piers14 » Sun, 24 Jan 2016 7:35 +0000
Of the standard OEM diff's the Mk1 Torsen is best, with the Mk2 torsen only slightly behind. The both work well on the road and on track.
Piers14
Re: Torsan lsd. ?
Postby Merlot man » Wed, 27 Jan 2016 12:44 +0000
thats a very good explanation piers , thanks a million
must now go looking for a torsan !!!!
brian
93 na s ltd
Merlot man
