Leaking injectors!
Leaking injectors!
Postby Merlot man » Thu, 14 Apr 2016 5:26 +0000
Hello all
I'm in the process of rebuilding the inlet manifold on the mk1 and one of the injectors is leaking from where it is housed to the fuel rail AHHHHH
Al was ok until I was fitting the wiring loom and I had the rotate one or two or them to fit the loom connectors ,is it simply that I've moved the seals and hav to take it apart again an do it correctly without moving them once they are in place ?
Any help / advice would be great
Thanks in advance
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: Leaking injectors!
Postby MX5Spares » Thu, 14 Apr 2016 6:58 +0000
Hi Brian ,seal must be pinched?? They are circular seals obviously so they swivel around easily without damage but maybe when the rail was pushed down it pinched it??
Postby MX5Spares » Thu, 14 Apr 2016 7:11 +0000
Hi Brian ,reply sent on other website ....joke
Postby sidewaysreilly » Thu, 14 Apr 2016 7:56 +0000
You have to make sure the rail goes down evenly .Put a drop of oil or grease on them first.
Postby Merlot man » Thu, 14 Apr 2016 7:57 +0000
Thanks for that Robert , ya I guessed as much it's just a pain having to rip them again !
The smell of petrol in the garage is nice though :shock:
Brian
93 na s ltd
Merlot man
Postby Merlot man » Thu, 14 Apr 2016 7:59 +0000
sidewaysreilly wrote:You have to make sure the rail goes down evenly .Put a drop of oil or grease on them first.
Ya I told to do that as well from nutz , I assume Vaseline will do the job ?
93 na s ltd
Merlot man
Postby sidewaysreilly » Thu, 14 Apr 2016 9:11 +0000
Yeah, you cant bate doul lube!
Postby Steve » Fri, 15 Apr 2016 12:05 +0000
lol
