Right, so need to change all the oils. Please guys just give me a heads up that these processes are correct, and also if someone knows the tools required off the top of your head that'd be great. Im borrowing a lift but its VERY time limited so have no time for errors and wont be able to drive anywhere to collect parts
Engine oil, that's easy enough, for gearbox i just wanna make sure i have this right (its 6 speed box)
-open fill plug driver's side of box
-open drain plug on the bottom of box
-2L 75w90 fully synthetic into fill hole
-close her up, done
diff (its a torsen)
-same oil as above, 75w90 fully synthetic
-remove fill plug (square plug on the side)
-remove drain plug on the bottom
-1L into fill plug
-close her up, done
do i need steel washers for all the bolts?
does the box need to be filled from 2 places? i read some contradicting info....
thanks so much!
Users browsing this forum: No registered users and 9 guests
