Hey guys, just wondering have any of you had intermittent starting issues before?
Basically the fuel pump isn't getting power sometimes, I don't think it's relays as I've already swapped the fp relay out for an admittedly second hand unit but I had the same issue.
I think it could be the cam angle sensor, I got it started last night and it was running lumpy and rich. I did a track day in it a month or 2 ago and it seems to have gotten worse sense then.
I can force the fuel pump to run by crossing fp and ground in the obd box in the engine bay. Would a cas cause a lack of power to the fuel pump? It could also be related to the immobilizer but I'd prefer if it isn't!
Sent from my ONE A2003 using Tapatalk
