Clutch Judder
Clutch Judder
Postby Paschal » Sun, 30 Jun 2013 1:01 +0000
I have always had a bit of a judder in 1st gear. You have to have the coordination of a brain surgeon to avoid judder, having to get left and right foot just bang on. It appears to be getting worse recently. Not as noticeable in reverse. No other issues with the transmission, no issues engaging gears and no issues through the gears. Bite point ok etc
Would it be the fluid, had a look this morning and it is BLACK! I think I should change the fluid and see what happens
Any ideas?
Its a 2001 MK 2.5 1.6
Re: Clutch Judder
Postby sidewaysreilly » Sun, 30 Jun 2013 3:10 +0000
It will do no harm to change it.
Re: Clutch Judder
Postby charged_rs » Sun, 30 Jun 2013 10:02 +0000
is that why you were concentrating soo hard when i flew past you yesterday coming back from lisburn ?
the clutch judder issue is down to a defective clutch disc and pressure plate from the factory- most mk2.5's suffered from it
Re: Clutch Judder
Postby Paschal » Mon, 01 Jul 2013 1:32 +0000
charged_rs wrote:is that why you were concentrating soo hard when i flew past you yesterday coming back from lisburn ?
Was that you? well spotted!
I had heard that about the mk 2.5 clutch, so it is true
Thanks for advice
