I got a full set of 1L wishbone bushings that I'm going to attack in the near future. I was planning on getting a couple of spares but should i just replace all the camber old bolt sets as good practice ?
A couple of the nuts look very crusty and might need the angle grinder and punch removal technique ?
Also what is the procedure for reassembly and realignment ? what do I need to maker or record settings prior to removal. Or will I just reassemble all and leave a full alignment to the shop afterwards ?
I will def need a full alignment , will a rough set up be fine for driving a few mile into the alignment shop ?
I might drop the rear subframe too for refurb, il see how the front end go first
