NCT
Re: NCT
Postby leamyj » Thu, 10 May 2012 9:07 +0000
autocheck wrote:yeah we have wiper linkage for mk2 and possibly the aftermarket air filter is effecting the emissions but if you put 1 ltr of dipethane (available in any good motor factor)and PUT THE FULL 1 LTR IN at low fuel the day before you do your retest it will pass no problem as the car is basically running on a mix of petrol/dipethane.I have done this about 10 times without fail. ignore the instructions on the bottle!!!!!!call me if you need anymore details .Thanks Robert
Ooohh..trade secret there lads :mrgreen:
Re: NCT
Postby sidewaysreilly » Thu, 10 May 2012 10:51 +0000
may get you thro the test but doesn't solve the engine running shite in the long term. A well tuned engine wont need it.
Re: NCT
Postby CashelMX5 » Fri, 11 May 2012 1:01 +0000
sidewaysreilly wrote:may get you thro the test but doesn't solve the engine running shite in the long term. A well tuned engine wont need it.
So what would you suggest to resolve the problem?
Re: NCT
Postby sidewaysreilly » Fri, 11 May 2012 8:40 +0000
A proper tune up.
Re: NCT
Postby CashelMX5 » Fri, 11 May 2012 11:27 +0000
sidewaysreilly wrote:A proper tune up.
Thanks for that. Now, knowing very little about mechanics, how do I go about getting aproper tune up?
Re: NCT
Postby sidewaysreilly » Sat, 12 May 2012 2:55 +0000
Start with a full service , oil, filter, plugs , air filter. Check erg valve is clean if fitted. They block apparently. Then a good hard drive up a long hill at full throttle to clean things out. The Italian tune up method.
Your cat may be knackered which could cause a fail.
Re: NCT
Postby CashelMX5 » Mon, 18 Jun 2012 12:46 +0000
Followed all the advice - put new cat on, topped up with fuel cleaner and fitted the wiper linkage I got off Autocheck (thanks Robert). The mechanic who put on the cat said that it had been replace already and that it was the wrong one - it was only suitable for a small 1100 cc car. Went back for re-test and thankfully got the all clear with the emissions reading like that of a new car - happy days to be back on the road, legally :D All we want now is plenty of :sunny: :sunny: :sunny:
Thanks everyone for the advice :thumright:
Re: NCT
Postby aquarian5 » Mon, 18 Jun 2012 5:23 +0000
Welcome back Tom, hope to see you around if we get a bit of summer sunshine... :roll:
Re: NCT
Postby leamyj » Mon, 18 Jun 2012 5:52 +0000
Nice one Tom :thumright:
All we have to do is get a run together now.
Users browsing this forum: No registered users and 34 guests
