no leaks any where no fluid loss
mintex brake fluid used (its blue)
Users browsing this forum: No registered users and 46 guests
Re: hard to change gear =/no leaks any where no fluid loss
Re: hard to change gear =/Mintex is very good so no issue there and no leaks 'must be clutch assembly itself.Try the bleeding first though
Re: hard to change gear =/what colour is the fluid in the master cylinder
Re: hard to change gear =/try starting the car in gear with your foot on the clutch.
Re: hard to change gear =/Sorry I thought you meant the bottle was blue haha.. usually brake fluid is light yellow but it goes black if air gets in it.. so that why I asked
Re: hard to change gear =/I know it wierd allright .. blue
i will look @ the slave cylinder to see if it is leaking If there id no leaks why would i have a spongy clutch pedal ?
Re: hard to change gear =/could be a little bit of air in that case. did you try bleed it again just to see??
Re: hard to change gear =/I will try bleed again
Re: hard to change gear =/well i got a brand new slave
i fit it and its still no better (solid pedal not spongy) the symptoms are (when moving and cold) *Hard to get into 2nd and 3rd *hard to get out of 1st
Re: hard to change gear =/Might be your master cylinder, have a read of this thread :
http://mx5ireland.com/forum/viewtopic.php?f=8&t=5430
Re: hard to change gear =/the master is dry
As in NO fluid??
Re: hard to change gear =/Dry???that wont tell you if the seals are fecked........
Re: hard to change gear =/no lose in fluid
dry as in not leaking
Who is onlineUsers browsing this forum: No registered users and 46 guests | ||
