hard to change gear =/
Re: hard to change gear =/
Postby sidewaysreilly » Sun, 06 Jan 2013 6:46 +0000
yes but seal can still be worn/damaged and bypass fluid . What travel do you have on the slave cylinder when you bleed it??????.........any????
Postby james » Sun, 06 Jan 2013 7:00 +0000
explain travel
james
Postby sidewaysreilly » Sun, 06 Jan 2013 7:45 +0000
get someone to press down clutch pedal and measure the amount the slave cylinder moves out.
Postby james » Sun, 06 Jan 2013 8:20 +0000
good idea =] i like that
what should i be expecting
james
Postby sidewaysreilly » Sun, 06 Jan 2013 9:05 +0000
12-14mm i'd say.
Should look like this at minimum;
http://www.youtube.com/watch?NR=1&v=0UK ... =endscreen
