import alignment settings
PostPosted: Wed, 22 Oct 2008 8:36 +0000
by ger
I need to get alignment settings for a 90 1.6 roadster.
in a hurry if possible.
the info from different sites seems to be conflicting.
PostPosted: Wed, 22 Oct 2008 8:55 +0000
by mx5ash
PostPosted: Wed, 22 Oct 2008 9:01 +0000
by ger
are these for a mk1 do ya think?
PostPosted: Wed, 22 Oct 2008 9:22 +0000
by mx5ash
Not sure deccy has a mk2.
Why you need them? the garage doing an alignment should have them no?
PostPosted: Wed, 22 Oct 2008 9:26 +0000
by ger
only fo uk/irish model not for jap import.
PostPosted: Wed, 29 Oct 2008 4:59 +0000
by Fergus
The 'Eunos Roadster Mk1' alignment settings have been around for years, go to another garage that has up to date hardware :D
That garage must be using equipment which is REALLY old.
PostPosted: Thu, 30 Oct 2008 11:04 +0000
by ger
i know, had to get it done quick for the NCT, the wheels were all over the place. Brought down some settings and the guy didnt even knoe the symbols for degrees and minutes, he just watched the slider on the screen.
anyway after about 1hr 20mins we were as close to lanny settings as possible, at this stage i ws doing most of the work.
had a caster problem with one of the front wheels, couldnt get it below 6, must be a bush on the way out.
Its cornering well now but pulling slightly to the left, i hve 5.5 caster on the left and 6.2 on the right.
PostPosted: Thu, 30 Oct 2008 11:06 +0000
by ger
i also have a broken 'a' key, must get a new keyboard.
PostPosted: Thu, 30 Oct 2008 11:25 +0000
by mx5ash
:lol:
Glad your sorted mate (nearly)
PostPosted: Thu, 30 Oct 2008 11:36 +0000
might be a bush or a stretched alignment bolt.. trussville Mazda sells them for 5 USD or so AFAIR
PostPosted: Fri, 31 Oct 2008 6:36 +0000
by MX5Steve
ger wrote:the guy didnt even knoe the symbols for degrees and minutes, he just watched the slider on the screen.
:lol: :lol: :lol: muppets!
PostPosted: Sun, 09 Nov 2008 10:57 +0000
by Fergus
srigley wrote:might be a bush or a stretched alignment bolt.. trussville Mazda sells them for 5 USD or so AFAIR
The Alignment bolts are KNOWN to bend in the Mk1s, Mx5Parts have the 'upgraded' ones. I changed all of mine a few years ago and yeah, the fronts were warped !
PostPosted: Fri, 14 Nov 2008 11:37 +0000
by 93 Mk1
Why is there a different between the Eunos and MX5 regarding these
settings ? I thought they would be all the same ?
