need to set my base timing,
are all timing lights generally the same
will this work ok?
http://tiny.cc/VGw2v
good timingneed to set my base timing,
are all timing lights generally the same will this work ok? http://tiny.cc/VGw2v ger
Yeah that one will do just fine. Where abouts are you there might be one local to ya in the club (sean has one in cork)
thanks ash, I'm in Avoca in Wicklow (near Arklow).
I don't mind buying one as I want to experiment with my base timing and timing maps on my ACU (bipes). I'm going to set 18 base timing and the ACU will pull the timing from 3000 -4000 rpm back to 8 degrees, then it will scale up the timing again between 5500-redline. Keeps it safe in the most knock prone rpm band. Works great on an NA cars, cheap too. I see a turbo in your future, you seem to be well on your way to the dark side. Blew away a new golf turbo the other evening, when we pulled up at the next set of lights he wasn't a happy bunny (German car owners eh no sense of humour) He'll think twice before bumper hugging a 5 again.
Fair enough Ger, At that price your as well off. Hmm thinking more sc tbh. Auto manifold is not the same as manual so getting a turbo mani could be tricky.
Must do something with my timing, Currently set at 10 with the link but need to sort that out. ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
Ash, its set at 10 when you install the link so that its reference point is the same as the actual timing. Have a look at your ignition map, the link advances the timing + fuel while reading the O2 sensors voltage.
If its set to 10, you don't need to change it again, the link will do it for you.
Yeah i know what your saying steve but my maps are way out v's the Benchmark map. I'll email you a screen shot of it.
Need to do more tuning, Actually what i need to do is drive up to galway some weekend and you can explain all this to me as i am just to dumb. And ger yeah afaik the link can increase & pull. Ash ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
Yup, plus it'll add or remove fuel.
When tuning you can download the current map, make changes and reupload. Then go out and do another run, see if you have any knock, if not, you can remove fuel + add timing until you do, then reduce timing a little to avoid it in future.
Sounds great apart from me not having a knock sensor.
Who is onlineUsers browsing this forum: No registered users and 19 guests | ||
