wheel and tyre setups
Postby mark » Fri, 19 Dec 2008 12:18 +0000
hi lads , i'm collecting a 91 mx5 eunos roadster tomorrow and i know the tyres are fairly worn so i'm looking for some general advice
should i keep the 14in original wheels and just source new tyres , and what brands and sizes are best ( not looking to rally the car too much :roll: ) but will need to use it in both dry and wet conditions as an every day vehical .
or should i look at getting a slightly larger alloy wheel and tyre set i.e. 16 / 17 if they fit ? , and would you know of anywhere in the wexford / waterford area doing reasonable deals
many thanks
mark
mark
Postby Steve » Fri, 19 Dec 2008 12:33 +0000
For a daily driver with some weekend fun I'd go for the lightest 15" wheels I could find (like the MX5 BBS wheels) with 225/45 R15 tyres.. Toyo Proxies from here :
http://www.camskill.co.uk/products.php?plid=m4b0s308p0
Postby mx5ash » Fri, 19 Dec 2008 1:03 +0000
Hi Mark welcomne to the forum,
It goes a but like this
14" is best for handling/acceleration etc
15" for good handling and good looks
16" handling ok more for looks
17" purely for looks
camskills or black circle are great for tyres at the min due to exchange rate, Don't forget to factor in fitting price.
As for the alloys, lightness is goodness. Rota do some which are pretty easy to source, cheapish, relativly light weight and nice to look at.
Postby Pete JB » Fri, 19 Dec 2008 6:40 +0000
I have standard sized Goodyear Hydragrip tyres fitted. They are 1 step below the F1's but specifically designed for the wet. I find that although not quite as good in the dry there's still plenty of grip, but in the wet when the Mx5 can be tricky they are a great tyre. No complaints so far.
Pete JB
Postby sspecdave » Sat, 20 Dec 2008 1:08 +0000
Welcome Mark.
Stay with 14" if the original alloys are good as this is the standard set up and tyres are cheap as chips.
185/60/14 H is whats recommended but 185/60/14 V will offer you a bit more grip but will wear faster.
Would also be worth getting 4 wheel alignment done when your at it.
Can recommend TOM GERAGHTY TYRES WATERFORD @ 05187377 OR
BLACKCIRCLES WITH DELIVERY ABOUT 26GB POUNDS.
http://www.blackcircles.com/home
I purchased these a couple of days back from blackcircles and dpd delivered in 2 days but you will need to organise fitting yourself.
[url]Image[/url]
Postby mark » Sat, 20 Dec 2008 7:48 +0000
thanks lads , think i'll go for the toyo t1 r in 14's as the original wheels are in good order
mark
mark
Postby mx5ash » Sat, 20 Dec 2008 8:47 +0000
Good choice, About as good as your gonna get. Your five will thank you. :)
Postby Geese » Tue, 23 Dec 2008 2:53 +0000
I've tried.
14" Prielli P6000s Good all round tyres. Should be cheap 60euro a tyre
14" Yokohama A539s Very cheap and VERY soft tyre that only lasted me about 6months. Stock power should be ok for 185wide Breakaway is very slow and is easy to drift about 50 euro a tyre.
15" Yokohama AO32 Super grip but really soft abd really expesive.
15" Nankang NS2 Ok tyre but they let go very fast and not really much fun becasue of that. 60euro from camskill.
Geese
