Heating & Water Gurgling
Postby graham » Wed, 04 Feb 2009 1:03 +0000
My heating isn’t working properly, it gets warm but never hot. Also I've noticed a gurgling sound coming from the engine, generally only when starting in the morning.
Any ideas?
g
graham
Postby NickD » Wed, 04 Feb 2009 1:08 +0000
You have lost coolant and it is now not full.
NickD
Postby graham » Wed, 04 Feb 2009 1:15 +0000
How do I check the coolant level?
graham
Postby NickD » Wed, 04 Feb 2009 1:18 +0000
Erm, look in the top of the radiator.
Top it up with 1/3 to 1/5 antifreeze and the rest water, deionised battery water if you have it. But also look to see if you are loosing water.
You will probably need to top up the expansion tank as well.
NickD
Postby graham » Wed, 04 Feb 2009 1:27 +0000
I checked that this morning, the rad isn’t full, it’s about an inch below the top, the rad water is very brown in colour. Should I top it up with just coolant as there is already water in it?
g
graham
Postby Steve » Wed, 04 Feb 2009 1:41 +0000
if its brown it might be a good time to give the rad a flush while you are at it, drain the old stuff by taking out the plug under the rad here :
Disconnect top rad hose and put your garden hose into it + run until the water coming out is clear. Refit rad hose + plug, fill rad + overflow bottle to the mark with coolant. Let the car idle up to normal temp then cool completely to "burp" it, then top up if needed.
If you want to completely flush the system, stick the garden hose in the bottom rad hose which goes into the block instead.
Postby graham » Wed, 04 Feb 2009 2:06 +0000
Thanks everyone...
g
graham
