I have been getting a rattling from the crankshaft alternator pulley for a while now, I thought it was water on the belt, when I sprayed wd40 on the belt it went away for a while but always came back.
Then yesterday I was setting the timing and noticed the pulley was wobbling and the timing mark on the pulley was moving back and forward slightly (bout 1 degree worth).
Is this a worn keyway on the crank?
Found these options if it is
Replace the crankshaft. A robust fix. Probably a $3000 bill comes with that.
Replace with a used engine. Also a robust fix . $600-2500, depending on who does the labour
Weld the crankshaft to repair the gap. Perhaps weld the gear in place. Some risk of failure. $ 100-700, depending on who does the labour.
Try the Loctite Fix described in this web site. Some risk of failure. $ 50-700, depending on who does the labour.
No one guarantees this Loctite Fix will work on your car. That's why there is a risk of wasting time and energy. If you are a do-it-yourselfer though, it may be worth your effort.
Anyone tried the welding or the loctite fix?
Should i try to re torque the crank bolt ( afraid of doing more damage if the keyway is damaged)
Here is the loctite fiz
http://www.miata.net/garage/hsue/crank/loctite_1.htm
Really appreciate some help for the more mechanically experienced members.
  FAQ
 FAQ
