coolant issues
Sat, 11 Jun 2011 3:11 +0000
by carolineoneill
Hi guys, I am new to the forum and a proud owner of a MX5 1.8 1998 and am having trouble with engine temperature. I got a new water pump fitted but temp gauge still goes up once I go over 60 mph. Its not a leak or dodgy radiator cap or blockage - anyone have this issue? any ideas? Cheers, Caroline
Re: coolant issues
Sat, 11 Jun 2011 7:51 +0000
by sidewaysreilly
could be air in the system or a dodgy thermostat . Worth replacing it as its probably old and they are cheap.
coolant issues
Sat, 11 Jun 2011 9:19 +0000
by mx5ash
Yeah try a new One and give system a hood bleed. You'd be surprised how much even a little air in it can block up
coolant issues
Sun, 12 Jun 2011 9:06 +0000
by jaybond
What's a hood bleed?
Re: coolant issues
Sun, 12 Jun 2011 11:55 +0000
by sspecdave
carolineoneill wrote:Hi guys, I am new to the forum and a proud owner of a MX5 1.8 1998 and am having trouble with engine temperature. I got a new water pump fitted but temp gauge still goes up once I go over 60 mph. Its not a leak or dodgy radiator cap or blockage - anyone have this issue? any ideas? Cheers, Caroline
Caroline,
Did you have this issue before waterpump replacement
You say above it happens
when you go above 60mph which would indicate to me that your radiator is blocked and needs replacement. The radiator may look good but if its brown in colour its a good indication its blocked, which will reduce cooling .
coolant issues
Sun, 12 Jun 2011 1:38 +0000
by mx5ash
jaybond wrote:What's a hood bleed?
Sorry meant good....
coolant issues
Tue, 14 Jun 2011 8:54 +0000
by jaybond
I should of figured that, I can be a little slow sometimes.
Re: coolant issues
Tue, 14 Jun 2011 1:20 +0000
by Paschal
sspecdave wrote:carolineoneill wrote:Hi guys, I am new to the forum and a proud owner of a MX5 1.8 1998 and am having trouble with engine temperature. I got a new water pump fitted but temp gauge still goes up once I go over 60 mph. Its not a leak or dodgy radiator cap or blockage - anyone have this issue? any ideas? Cheers, Caroline
Caroline,
I had the same problem with my 2006 Honda Accord recently. The garage checked everything and we were all scratching our heads. As a final resort they switched the Radiator and this solved the problem. Car is relatively low mileage and well looked after, radiator looked perfect, but it was obviously blocked
Re: coolant issues
Tue, 14 Jun 2011 5:52 +0000
by sidewaysreilly
a good garage or an informed enthusiast will know if its a radiator thats at fault . Infared heat gun will show rad faults.
Re: coolant issues
Thu, 23 Jun 2011 1:28 +0000
by 93 Mk1
I had this problem several years back with a 1.6 Mk1. Exceed 60 mph and the temp would climb to the point of
boiling over. I replaced the thermostat and it was fine afterwards. As the lads say, it's a cheap fix so it's no harm
to rule that out before proceeding further.
Re: coolant issues
Mon, 27 Jun 2011 3:46 +0000
by Geese
Is the air side of the Rad blocked? Too many bugs and flies?
