Users browsing this forum: No registered users and 48 guests
high emissionshelo everybody i bought a mx 5 and cant get the car threw the nct with the emissions or high and have tryed every thing except changing engine its 1993 enuos mark 1 change plugs cat manafold air flow meter even took the car 2 a mazda dealer they cant help can any one help will try any thing
Re: high emissionso2 / oxygen sensor or airflow meter impact on emmissions, try changing those out
Re: high emissionscould try diptane, depending on how much the reading is out by, wont solve the problem but might get it trough the test.
has the car been serviced and are the wires going to the o2 sensor intact. You som'bitches couldn't close an umbrella
high emissionsWhat are the readings, might give some clues as to what's up as different readings indicate different things. Have you changed leads? O2 sensor?
http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
high emissionsAlso what are they testing it as? Its a jap import yes? No high idle test?
Re: high emissionsHI' HAD A MATES WHO'S 00 MX5 FAILED EMMISSIONS-SWORE ON THE USE OF REDEX FUEL ADDITIVE HAD FIXED HIS PROBLEM ?
Who is onlineUsers browsing this forum: No registered users and 48 guests | ||
